TV and Video
This tv does not turn on when reviewing this diode was found in short
servi-pecas
hace 6 años
hace 6 años
Gentlemen of I repair, have a good day, I ask you very resolutely what is the replacement of the RH3G diode this is a 29 "panasonic tv damper and is not available in commerce, I thank you for your comments or advice
franciscovallarta
hace 6 años
hace 6 años
https://www.yoreparo.com/tv/televisores/tubo/preguntas/1346126/necesito-reemplazar-diodo-damper-rh3g-en-tv-panasonic
servi-pecas
hace 6 años
Thank you very much for the answer Mr. Franciscovallarta I will look for it in the trade and then I will tell you
servi-pecas
hace 6 años
This diode could not be found, can you tell me if the RS3F can replace it?
servi-pecas
hace 6 años
Mr. Franciscovallarta as I said the diode that you suggested could not be achieved, at the suggestion of a colleague replace it with the RS3F and the TV worked perfectly without heating the diode
Thank you for your support
