TV and Video
Tv daewoo with horizontal lines
john chriss
hace 6 años
hace 6 años
Hi, very good day blessings ... I have a daewoo tv that on the bottom does not look and almost half screen up looks image but with the lines ... I would like to help me with this problem .... Thank you
hecjaquez
hace 6 años
hace 6 años
Hello buddy your problem is in the vertical stage checks the capacitors attached to the integrated and changes the integrated, check cold welds or false contacts. comment how was it God bless you
john chriss
hace 6 años
Thank you I put it new integrated LA7841 and now it gives me an orange horizontal line and completely closed ... That plate brings a lot of capacitors from a very small squares
john chriss
hace 6 años
I already did it and change the vertical to a new one ... With the previous I had open screen halfway and when I replace it with oneself but again I close the screen with a horizontal line in the middle ...
JuanD333
JuanD333
111
hace 6 años
hace 6 años
problem in vertical stage, indicates model to be more precise in helping you
john chriss
hace 6 años
The model is DTQ20D3AS
JuanD333
JuanD333
111
hace 6 años
friend check filters adjacent to the vertical IC or replace them all since they are very varatos and the diode that has in front, if the fault persists measure voltages in the vertical (knowing that voltages must have with the diagram of the tv) and there are different readings change it
JuanD333
JuanD333
111
hace 6 años
http://yoreparo.com/tv/televisores/tubo/preguntas/906309/diagrama-tv-daewoo-dtq20d3as in that post is the diagrma, compare and comment results
