TV and Video
TV Sharp 21M-FG1L turns on but no picture.
Televisor SHARP 21M-FG1L
Olvin Dagoniel Villanueva
hace 6 años
hace 6 años
good day Fellow of the forum, today I got a sharp tv 21m-fg1l, which came with the screen broken but no damage to the plate, at least visual. I dismantled the rest of the screen and cleaned all the waste so I could put the other one, when I had everything well mounted, I decided to turn it on and turned on with its normal audio, and if I change channels I hear that it is normal, but there is no image , the screen is completely dark and does not light the filaments of this one. I measure the B + voltage and reach 124 VDC, the vertical ic is also reaching the voltages normally. I ask you for your cooperation so that you can guide me in solving this problem.
Ingnio
Ingnio
2.236
hace 6 años
hace 6 años
If you do not turn on the filament, there can be no frame, so the screen looks dark. Check the matrix plate, components, filament voltage, the socket that matches the connections to the terminals of the TRC you put. I leave you Diagram. Greetings. Sharp 21M-FG1L.pdf [1.09mb]
