It's a good idea about the trimmer. Many teachers recommend it. I commented that when we have placed the capacitor, we have never been tuned well. change channel, you see some stripes and stabilizes thing for three seconds but it shows. Maybe some companion in your town can provide capacitors for some chassis. Comment if you tried the channel selector and if the signal is seen on another tv. Greetings. felipe ascencio
Yes, the same thing happens to me, I was more than 3 hours to see if I put it to point and do what you say, when you change the channel you see, at half a second it "tunes" and then the image remains. But well, I said enough and I remain like that, I would say 95%. You decide that placing a coil of another chassis, it will be fine? only for curiosity. regards
partner. when placing another coil, what we have achieved is that time is reduced to tune, but nothing at 100%. if you have achieved 95% it is not good, it is excellent. it's good that you've achieved it Congratulations. Greetings. felipe ascencio
and what was the result? .- This way is what we use, we have already prepared a channel selector of those mechanical "turret" of a tv bn. you can also assemble a peak-to-peak voltage probe, there are two options, one like the one in electronic community but using glass diodes since these support 50vcd maximum, or using the picerno ing probe, we have armed both with good results So in the jungle you can see which is the video output pin and place the probe and measure if you have vpp. (peak to peak voltage). comments .saludos. felipe ascencio
The problem may be the jungle. but before changing it, check the voltages and weapons of the ingpi vpp probe so you can see if you have video output on the corresponding pin. place the selector and try to pass the color fi signal to tv bn. If you do not have a signal generator, in a cyber you can make one, you connect it to the antenna by means of a DVD. so you can have the fixed video output. Tell us what the jungle is, in case we have some similar diagram. Greetings. felipe ascencio
The diagram is this: http://www.archivotecnicosaurios.com/descargas/tv/seccion_ordenada/9810_Chassis_LA5-A.pdf
already download the diagram, but you armed the vpp probe ?. the image stops being seen, but the sound is left or lost. Check with a logical probe the data bus (or pulse train) of the memory to the channel selector. in an electronic community there is a probe which is useful because it has low pulses, high pulses and pulses. On Saturday we will look at the diagram and try to provide more information. Greetings. felipe ascencio
the diagram that you indicated has the jungle la76818am. as for the selector if possible with the voltages that "pass" the color tv signal to tv bn. In elpin del agc place a regulator 7805 so you can vary the voltage of 1.5 / 3.5 vcd. with this we will leave doubts about the selector. with the vpp probe check pin 46, it should have 2.5vpp. and in pins 19,20,21, it should have 4.6 / 4.8vpp. Greetings. felipe ascencio
By measuring everything and finding it right, I went for my first suspicion, capacitor VCO coil. Take out the capacitor, and connect the coil alone, and to my surprise I already tuned to color, but without the capacitor it was not perfect, I tried it with a 29p, it only had color in one point, followed with a 22p, I improved, but the same story, from here I jumped to 9pf which was the value that I had at hand, not its intermediates and I improve a lot, but not perfect, I will have to try 15pf and 18pf, maybe the channels are stable, but they have rain and audio interference.
it's good that little by little you are achieving it. we have a sanyo diagram in which the condenser that has the vco coil, we place it from 18 on the outside, that is, we place the coil and on the side of the chassis we place the condenser, just a couple of tweaks. There is a document in the network about how to work with that coil. Greetings. felipe ascencio
Yes, that's what I was doing, but I just do not have the intermediate values to those, in addition to the coil the touch, since I just got the plate of that TV, so I said, as a last resort I try to move the coil, so what I did and saw some image after giving it about 4 laps. Disarm, take out the capacitor and connect it with nothing and gave me an image, but not perfect, so I tried with capacitors but with no improvement compared to the single coil. So I think directly using a trimmer (variable capacitor), what do I decide? Now spend 3 full hours trying to alternate capacitors.
